02-22-2008 11:31 AM - edited 02-22-2008 11:33 AM
02-22-2008 11:42 AM
i had a related problem, but not totally similar.
a set of possible tests to be done, in specific order.
1) choose all the tests, in the order you want, from radio buttons. the order of clicking will define the order of the tests.
2) all the test are now displayed in a different screen, using a table, where one can drag and change the order of the tests.
3) in the UI loop, there is a record at every stage of the present test, the next one and the last one to be performed. a 'back' button allows to come back to the table screen. activating the button induce recording of important elements for plausible future tests.
4)the list screen with the table also allows you to jump a test, redo a test, or go to any test, just by double clicking the relevent element in the test. here, some care is required in order to keep trac of relevent information for each step. that is why in the state machine loop, i always have a 'init' step for every test, independant of previous test. it takes into account if previous necessary test has been or not performed.
the tric for all that was recording the 'next' test and 'back' info. hope this help.
02-22-2008 11:50 AM - edited 02-22-2008 11:53 AM
02-22-2008 11:52 AM
Thanks for the Info Gabi1, I have to keep this all on one screen and as simple as possible because there is no telling who may end up using the test fixture. I will keep this in mind though.
02-22-2008 11:57 AM - edited 02-22-2008 12:02 PM
Matthew,
You nailed exactly what I want to do. Is there any way thatyou could put together an example for me. I tried to do it a long time with a list box but I could not get it to work without having to doble click on each to get a change in the symbol that I was using to indicate whether or not a test was to be performed. I love the list box Idea.
Another advantage I would have in using a multi column listbox is that I could include the pass fail information next to the test. I am doing that now but with another custom control that I have to manage and deal with everytime I wanted to add a test.
Please show me or direct me to an example of this.
02-22-2008 12:12 PM
02-22-2008 12:34 PM
I love this, I am going to play around with this a bit.
here are my thoughts.
Matt how would this work with a multicolumn listbox,
This is great stuff,
02-22-2008 12:41 PM
02-22-2008 12:50 PM
02-22-2008 01:20 PM
