Make objects visible on tab control
Hi all,
There is a "tab control" with 2 pages. First page of "Tab" has "tank" and second page has "knob". I want to make "tank" visible on page 2 (which is on page 1) like "slide" control but "tank" and "knob" must be on own pages.
(I don't want to create two times of the same object (tank) and then don't want to use local or global variables)
Many thanks!
Thanks!
~drycsr~
(2,756 Views)
Accepted by topic author drycsr
HI,
Run the attached VI and check.. I guess this will solve your problem. I just took out the tank out of the tab control and placed it free on the front panel. Then selected it by clicking it and then used the arrow keys to move it over the tab control. When we run this this tank will be visible in both the pages.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved;))
(2,738 Views)
Hi Nittz,
Thank you so much, it works! And all kudos to you  😉
Best regards!
Thanks!
~drycsr~
(2,734 Views)
