Make current value default programatically
Could someone please help me?
I'd like make current value default in my VI programatically. I could do it. But I need that my program work inside while loop and I haven't getting it.
See my vi attached.
Thanks, J.
Note: My Labview is 7.0
(3,369 Views)
I don't think you can do that programatically.  What you can do is write the value to a file whenever it changes and you want to make the new value default.  Then at the beginning of your code, read the value from the file and put it into your control by using a local variable or property node.  Anytime you want to revert to default in your program, you would have to read the file to get the default value.
As an alternative to using a file, you can use a global variable to store the default value.
Message Edited by tbob on 10-18-2005 01:14 PM
- tbob
Inventor of the WORM Global
(3,364 Views)
Jota,
Please see the following link for some helpful additional information explaining a workaround for this issue and has an attached example code.
http://digital.ni.com/public.nsf/websearch/03FC177242ED0DC0862564FA004B56D8?OpenDocument
-jeff
(3,345 Views)
Check on the "property saver" offered freely by Konstantin on his web-site found here
http://www.kshif.com/lv/index.html
Ben
(3,336 Views)
