Machine GUID fixed like MAC address?
Hi all,
Does anyone know if th Windows Machine GUID is fixed in memory.  Is it fixed like the MAC address is?  Is it reliable?
It can be found in the registry under LOCAL MACHINE\SOFTWARE\Microsoft\Cryptography.  Is this the spot for all operating systems?
Would it be possible to use the GUID instead of the MAC address for software activation purposes?
Battler.
(21,698 Views)
Hi Battler,
Check if this helps you:  http://www.itnewsgroups.net/group/microsoft.public.windows.server.general/topic13923.aspx
and this: http://www.derkeiler.com/Newsgroups/microsoft.public.security/2002-11/6898.html
Hope it helps answering some of your questions.
TN
Currently using LV 8.5
logo
(21,680 Views)
Not really.  Thanks anyway.
Anyone else?
(21,677 Views)
This thread suggests that one computer can have a random GUID which is based on its MAC address but has many other random chars in, so it is not going to be the same everytime you generate a GUID on the same machine.
(21,673 Views)
I dont want to generate a GUID.  I want to use the GUID at that registry location to uniquely identify a PC.  I don't want it to change.
Thanks.
(21,670 Views)
Hi battler
The Machine GUID is fixed in the registry, but is changable with the right privileges. Not that you generally would want to change it, especially if I understand your intended use correctly. Changing it would just hurt the person changing it since the software would no longer work and if you hash it to generate your activation code it would be nearly impossible to "guess" for someone else.
As to if the MachineGUID can be found in the same please in the registry for all versions of Windows I can only say that it is in the same place in XP, Vista and Server 2003.
Best Regards
David
NISW
(21,652 Views)
For anyone else who desires to answer questions posted by battler, you should read this thread, especially this response.
(21,623 Views)
