LakeShore 325 Ramp/Step
Hi guys,
Need some help in how to make a ramp with some setpoints, and a step form for the same instrument (lakeshore 325 temperature controller).
I have already read the LakeShore 325 manual, that says i can make as many setpoints as i want, and divide the ramp in various segments.
That was exactly what i want to do, i want to allow a maximum of 4 segments per ramp. I can't use the PID controller. And i'm not sure how to do it, because the ramp VI from the instrument driver only allows 1 setpoint to wire. Do i have to put that in a loop, with a interval of temperatures? Like, from 200 to 300K, then insert a setpoint with a delay, etc. I'm pretty confused with how to do it.
If anyone, knows how to work with it, let me know, please.
Thanks.
TN
Currently using LV 8.5
logo
(5,108 Views)
And the Ramp VI available with the instrument driver, only allows to wire a bolean (T/F) into the setpoint of the ramp.. 😐
TN
logo
(5,102 Views)
Hi THN,
Do you use the PID toolkit?
Have a look at this KB : How Can I Generate Setpoint Profile in LabVIEW For a Control Application?
Hope this helps.
Could you share your instrument driver too please?
Thanks in advance.
Best Regards.
Romain D.
National Instruments France
(5,090 Views)
 Hi Romain,
Thanks for your reply, i was missing 1 of the drivers function that was "configure de setpoint", which means that i was trying to make the ramp with the function "configure ramp" but the only option there for the setpoint was to wire to a boolean. And that was my problem.
Now, i'm having some questions about the best way to do the loops. From 1 max temperature to a minimum, the ramp will have rate, after that max or min been reached, i will have to do a delay for cooling and stability. And i will have to introduce a new max and min (2 setpoints..i think) and the new rate for the ramp. I dunno if i'm explaining well. Tell me if you understand me.
Thanks for your reply.
TN
logo
(5,074 Views)
If you want i can add the instrument driver in attachment.
Any tip will be welcome. Thanks
TN
logo
(5,057 Views)
Is this heading the good way?
Please leave me some feedback.
Thanks.
TN
logo
(5,039 Views)
