10-25-2007 06:59 PM
10-25-2007 11:23 PM
RL,
The suggest values button is meant for after you see your target in MAX so if your target is not even showing up, you wouldn't be seeing this. I would ensure that you have the most up to date version of NI-RIO (2.3.1) and MAX. There is a problem specific to MAX 4.2 which may be causing your target not to be seen so I would make sure that your MAX version is later than 4.2 and then explicitly follow these steps:
If this still does not work, I would try these same steps on another computer if possible to rule out the parallels setup as a potential cause.
Craig D
Applications Engineer
10-26-2007 04:00 PM
