Mac Path separator
I am trying to port a labview-vi written in windows to mac. In windows, it uses at DLL, so I converted it to a Mac Framework. Everything is working well. But I have one problem concerning the path separator: On Mac, LabView uses a colon as separator, which surely works well with the labview-vis. If I pass this path (by convert to string-->call library node) to an external framework, the framework expects a separation as used in the terminal by a slash (/). Is there any way to use slashes as separator or to convert the path to a path the framework understands? If not, the only solution is to write a conversion on my own, but is there a better solution?
Thanks!
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(4,363 Views)
Accepted by topic author cschneider
For some Mac path/string manipulation pointers, see this blog entry .
It looks like the function you want is vi.lib/AdvancedString/Path To Command Line String.vi
(4,341 Views)
Thank you! That's it!
THINK G!! 😉
(4,336 Views)
