MS Office Report Toolkit Formatting Column Header data as a Row in Excel
....sorry for the duplicate post.....I'm having issues this morning.
I know I'm going to feel silly when I get the answer for this one.  But I'm not getting anywhere on my own now.
I'm using the MS Office Report Toolkit to create an Excel report from a table in a LabVIEW application.
I spent some time figuring out how to create Named Ranges in the Excel Template I created.  That seems to be working, because I can see the inputs to the icon on the LabVIEW block diagram.
The problem I'm having is with the Table's Column Headers.
I created a Named Range that is an entire row of my Excel Template.  When I use the property node to send the Column Header values to the template, the data appears as a column in the spreadsheet.  So far, I haven't been able to figure out how to enter this data as a row instead of a column.
Is there a way?
Patrick Allen: FunctionalityUnlimited.ca
(3,848 Views)
Accepted by pallen
Looks like I found my own answer.
Seems that all I need to do was convert my Header data into a 2D array.
Don't know why that one was so tricky to figure out.  But it's working now.
(3,846 Views)
Great!
Usually you create a Row input, it will get in Row.
You create as column input, it will fit in column.
(2,299 Views)
