MS Access Runtime Activex Object
Hello All,
I have one pc where I installed Access 2010 Full version and one pc with a Access Runtime.
On the pc with the full version i can create a ActiveX "Access.Application" Class and run all
properties and methods.
That's not possible with the Runtime version. The Reference to the ActiveX Access Runetime is always Null.
I found this side http://support.microsoft.com/kb/210132/en-us to solve the problem, but I didn't know
how to create such a source code in labview.
In the false case of my VI you see the runtime method, but I do not know how to continue
at this Point (relating to the link):
Run-Time Version of Microsoft Access
4. Type the following procedure
Does somebody know how to create the "GetObject" Method in labview?
Thanks!
(4,378 Views)
Did you have a look into this whitepaper? I think you can find some usefull help there.
Converting Visual Basic ActiveX Examples to Equivalent LabVIEW
http://www.ni.com/white-paper/2734/en
Thomas
(4,343 Views)
Thanks for reply.
Yes I know it but it didn't help.
I wrote me an VBScript and call it over System Exec.vi with the service WScript.exe.
Until now, noone could help me with this issue, also in other discussion boards.
(4,341 Views)
Sorry, but I can't help you, is a serious problem, or this has not solution for now.
http://www.cimaware.com
(4,255 Views)
