MOXA, RS-485, ModBus RTU
@Gadjetins wrote:
Why do you have an object constant at the beginning of your code?
What is the first subVI called, the one generating the error?  Why is it there?
Message 21 of 52
(1,539 Views)
I do not understand why I do not have the last function (close)
Message 22 of 52
(1,529 Views)
I just started to understand labview and looked in one of the examples (not from the library)
Message 23 of 52
(1,523 Views)
Good. Let us know if you are able to read registers from your device.
Message 24 of 52
(1,519 Views)
I'm sorry, I put it wrong! I am still poorly versed in labview and did not refuse help, my English is wrong ((
Message 25 of 52
(1,517 Views)
So, were you able to run the example I provided?
Message 26 of 52
(1,501 Views)
I can not find the last element of the circuit, if it is "modbus master out" then the program ends with an error window
Message 27 of 52
(1,489 Views)
What kind of Modbus driver you are using?
Message 28 of 52
(1,486 Views)
please tell me where the address of the device is indicated??
Message 29 of 52
(1,483 Views)
Message 30 of 52
(1,482 Views)
