MIDI out with Labview and windows 7
Hi there,
I'm currently doing a simple project in Labview.
Reading the voltage from DAQ, if voltage in channel 1 > 0.5V, laptop plays "do",
                                                         if voltage in channel 2 >0.5V, laptop plays "re"
                                                         if voltage in channel 3 >0.5V, laptop plays "Mi"
I know how to deal with DAQ, but I have no experience in MIDI, I don't know how to make laptop play musical note.
Could anyone give me some references or examples in this field? Thank you so much!
(4,453 Views)
Accepted by topic author yatang
Hi yatang,
LabVIEW has functions to play WAVE files. You could supply wavefiles for your DoReMi notes and play them as needed…
Do you have a MIDI interface?
Do you have a driver for that interface?
Do you have a LabVIEW driver for that interface?
It's the same as with any other interface/device you want to control programmatically: you need a suitable driver accessable from your programming language!
(4,448 Views)
You can use ActiveX to call Windows Media Player for MIDI files.
George Zou
(4,442 Views)
wow great idea! I can play "doremi.wav" as needed!! That's much easier than MIDI.
Thank you so much!
(4,426 Views)
hi,
do you use your vi within a windows system? If you do so, you could use the winmm.dll to play midi notes on your speakers,
as shown in this projec by jallen88 :
https://decibel.ni.com/content/docs/DOC-19902
 but I agree, as Gerd pointed, using .wav files is much easier in this context
(4,419 Views)
