‎02-26-2015 03:26 AM
Can I have some help for using the dll of the MCP2210 breakout board within a vi in order to output hexadecimal chain through the SPI serial bus and some digital signal to an evaluation kit board ?
I have found some links here, but they are for older version of LabVIEW and DLL.
Thank you for the answer.
‎02-26-2015 07:56 AM
It doesn't matter that the examples are for an older verison of LabVIEW and DLL.
Concept of *how* to do it remains the same.
‎02-27-2015 06:32 AM
Well, so , how ? Have you an idea ?
It would be more useful for me, thank you.
‎02-27-2015 07:32 AM
You said that you have found some links. FOLLOW them.
‎05-18-2015 03:20 PM
That was a useless reply.
‎05-18-2015 03:21 PM
I have a similar problem.
‎05-19-2015 01:32 AM
Hello LYNNS,
I am happy (!) to see that I am not the only one who have difficulties to use MCP2210 DLL with LabVIEW.
Because of the no ( stupid ?) answer, I change my project and decide to use LabVIEW with Arduino UNO via the LINX programm :
https://www.labviewmakerhub.com/forums/viewtopic.php?f=12&t=528&p=3300#p3300
Now I developp an other application with the good help of samkristoff !
Hope this can help you, good luck !
‎05-19-2015 03:22 PM
If you want a good answer, ask a good question. "Can I have some help?" is not a good question. Post your code, explain what doesn't work, include the text and error code for any errors that occur.
‎05-19-2015 03:38 PM - edited ‎05-19-2015 03:39 PM
@JP67 wrote:
Hello LYNNS,
How is the "difficulties" of MCP2210 DLL any fault of the LabVIEW community here????
It is a DLL written by Microchip. Blame them them instead.
And for your information, no one here is under any obligation to help you with YOUR project.
It is YOUR project. Not our project. Talk about being a narcissist.
‎05-19-2015 04:57 PM
Thank you for the input. The only problem I have is that I need to upgrade from 2011 to 2013 to run.
