Lsm303 read data
hi, i'm Vincenzo, an electronic engineering. I'm realizing a work about LSM303, accelerometer and magnetometer, I've to work with Arduino and Labview: can someone help me with the implementation of the .vi to read acceleration data and magnetic field data into two graphs?
Thank you for the answers.
(3,486 Views)
Hi Vincenzo,
I can send you a typical example to read an analog input from Arduino with Labview through "NI Labview Interface for Arduino Toolkit". Starting from this example you'll can modify it for your purpose. Have a good time!
Enzo
AE Senior
(3,459 Views)
Thank you so much. I'll try to learn how to use these two powerful instruments, Arduino and Labview.
I wish I can ask something else if I'll need it!
Best regards.
(3,450 Views)
Hi! Working and studying various documentation about this sensor, I've found a sketch for Arduino. I've a question: why getLSM303_accel and getLSM303_mag functions are realized in two different ways? I would understant to be able to interpretate this code. These are the function:
void getLSM303_mag(int * rawValues)
  Wire.beginTransmission(LSM303_MAG);
  Wire.write(OUT_X_H_M);
  Wire.endTransmission();
  Wire.requestFrom(LSM303_MAG, 6);
  for (int i=0; i<3; i++)
    rawValues[i] = (Wire.read() << 8 ) | Wire.read();
void getLSM303_accel(int * rawValues)
  rawValues[Z] = ((int)LSM303_read(OUT_X_L_A) << 8 ) | (LSM303_read(OUT_X_H_A));
  rawValues[X] = ((int)LSM303_read(OUT_Y_L_A) << 8 ) | (LSM303_read(OUT_Y_H_A));
  rawValues[Y] = ((int)LSM303_read(OUT_Z_L_A) << 8 ) | (LSM303_read(OUT_Z_H_A));
I thought to realize in egual ways these void.
Thanks, regards
(3,325 Views)
How is your question related to LabVIEW? Shouldn't you be posting to an Arduino forum?
(3,317 Views)
