Lotto + Point System
Hello everyone. I am currently in the process of making a game. In this game I want a player to press a button and have random digits 1-9 roll. I have completed this, but I also want it so that if a player rolls the same number, he gets a point. I have got the basic idea of this, but I don't know how to make it so that a point is added to a digit. In my program, the point system is not consistent. It never adds on. Anyway to make this smoother or fix it all together?
Message 1 of 11
(5,336 Views)
You should remove the logic you have and add a simple shift register and a case structure to increment the score if the two numbers are the same.  See snippet and also link for shift registers.
Shift Registers
-Matt
Message 2 of 11
(5,293 Views)
Accepted by topic author scumbagsteve
There is more than 1 way to skin a cat.
Spoiler
"Should be" isn't "Is" -Jay
Message 3 of 11
(5,279 Views)
Smiley Surprised i like those big indicators. I like your method better, i fixed the problem, but i didnt optomize it in my example.
-Matt
Message 4 of 11
(5,272 Views)
Personally, I would just use the OpenG Random Number.  It would be less random numbers being generated (2 vs 18), which should make it more efficient than the Riffle.
Message 5 of 11
(5,230 Views)
Okay Jeff.  You initialize an array of 9 zeroes, then Riffle that.  I wonder what the result would be?  Smiley Wink
EDIT:
Is there something wrong with the code capture tool?  I see your snippet says it is LabVIEW 2013.  But when I go to drag it into a LV 2014 block diagram, it says it can't convert and it is a LV 2016 file.
Message 6 of 11
(5,219 Views)
I had the same thought.  But then I actually looked closer.  Jeff is using the Index output, which tells you where each element used to be.  So he is actually getting 9 non-repeating random numbers (0 through 8).  But then he only uses the first element, which seems like a waste to me.
Message 7 of 11
(5,206 Views)
You're right.  Forgive me Jeff.  I couldn't see that from the image.  (And I couldn't drag it into LV like I tried to play with it.)
Message 8 of 11
(5,199 Views)
EDIT:
We should discuss that on the dedicated thread Here
I admit I did try to prove my point of using several methods to skin a cat.  Surprizingly, the color boxes were "Work In Progress" for a current project (The Captions will display with a format specifier of "%.1d °C" the Value property is to be glanced at from across the room will display an type-def Enum selection) 😉
So, I did attempt to show the CCT in 2013 (the OP's Original version- I Hit Ctrl+I, if you don't know why Ctrl+I was used, look into finding an old QRC) Since the color boxes make no sense out-of context, I added in the FP with the CCT.  Riffleing an array and using the index output was a nice trick I learned 'round here
(Dr. Kinion I assume) and since it is no longer Biased and some arguments persist about how rnd really works Riffle.vi (Although Im sure there is a PRNG in there somewhere) seemed appropriate to generate a 0-n random, non-repeating integer series.
Call it a waste of <1kbits if you want Tim!  Hardly the kind of optomization needed for a user clocked mouse-click!
Serendipity is alive and well on the forums today
Message 9 of 11
(5,179 Views)
thank u all!
Message 10 of 11
(5,165 Views)
