Loop communication
Sup guys,
Is there a way to make a VI outside a loop to take data from a VI that is inside a loop while it's running.
(My problem is that I have sub vi that has a loop inside of it and I want another VI that cannot be located inside of it to take data about the loop iteration)
You'll find a screenshot attached to this
(4,068 Views)
Look into queues, notifiers, events, or even functional global variables.  These are all common practices for transferring data between asynchronous processes
(4,060 Views)
Accepted by 77maxmustermann
This is one of the standard problems in Labview. You can use for instance a shared variable, stream, notifier or queue to communicate between the loops. Here are some examples: https://www.ni.com/docs/en-US/bundle/labview/page/communicating-data-between-parallel-sections-of-co...
The easiest is probably to take a shared variable.
(4,047 Views)
Thanks it should work
(4,044 Views)
Whatever is reading the data will also need to be in a loop of its own if you want to constantly get the updates.  If not in a loop, it will only read once.
(4,041 Views)
Thanks for the warning. It's already the case
(4,017 Views)
