Lookup Table 1D no sign
Meanwhile, when I tried to drag the snippet it refused to display on my block diagram.I tried many other snippets available on the forum, but all of them display a forbidden sign. It means snippet are not working on my LabVIEW platform.
I am using LV 2012 licensed version.
Any suggestion please.
Thanks.
Message 21 of 23
(553 Views)
Sounds like you found the answer to the first question, about what will be the result when there two identical X values with different Y values.
As for snippets, try dragging them to your desktop first, to create a file, then drag that file onto a block diagram. Some web browsers do not handle drag and drop the way LabVIEW requires (maybe they transfer the image URL instead of the image data for example).
Message 22 of 23
(549 Views)
Wow,,great.
It worked. Thanks a ton.
Message 23 of 23
(545 Views)
