08-13-2012 12:07 AM
I want to create Lookup table using Control Design Simulation toolkit (Lookup Table 1D). Why when I select the VI (Lookup table 1D) from the functions palette it does not carry the VI? I use full liciense Labview software. Anyone expert please advise me..thank you
01-22-2013 02:32 AM
I am also facing similar problem. I am using licensed version of LabVIEW 2012 on PC with Windows 7 (64-bit) installed.In my case all three VIs (1D,2D,3D) are not working.
Could you sort out the problem?
Arihant
01-22-2013 02:41 AM
01-22-2013 02:49 AM
Do you also have a license for the toolkit? Maybe it was installed in evaluation mode and it now expired. Just guessing....
01-22-2013 05:53 AM
I am using labVIEW 32-bit.
By "not working",i meant to say that whenever I try to drag and drop the lookup table pellet on block diagram it refuse to appear.
01-22-2013 05:59 AM
@altenbach
I have licensed copy of "control design and simulation" toolkit installed.
The pellets appear on Block diagram>>Functions>control design and simulation>>simulation.
But when I select any of them and put on block diagram, symbol of forbidden appears.
Kindly suggest any reason and remedy.
01-22-2013 07:43 AM
What happens if you find the VIs on disk and double click on one of them to open them directly?
MIke...
01-23-2013 12:02 AM
I couldn't understand you properly. Which VIs?
If you meant any VI, yes they open and run succesfully.If you talking of a VI in which lookup table pellets are embedded, I have not tried any such example.
I will find one and run and then we will see if it works that way.
Thanks anyway.
01-23-2013 09:25 AM
I'm not sure what you mean by "pellets", but yes if you can find a VI that alreadty has them in it, we might be able to find out what the problem is by trying to open it.
Mike...
01-24-2013 02:36 AM
Hi Mike
I am attching image file with this post which shows lookuptable pellets (or VIs or functions).
I tried finding VIs which use this function but couldn't. If this function works on your system, kindly create an example and post.
I want to see if it works on my PC.
Thanks.
