Looking to Search and Sort String Twice, though am having issues
I am inputing from an access file a test library, the files in the access file are out of alphabetical order...thus I search and sort and bring these into LV in alphabetical order.  But I am running into the issue of trying to further search and sort the second column of info via the model number:
example:
Model ............. Model #
Zetor               55
Challenger        55
Ford                55
Zetor               66
Challenger        66
Ford                 66
Zetor               45
Challenger        45
Ford                45
Zetor               96
Challenger        96
Ford                 96
Need to Return the Files as per below:
Zetor               45
Challenger        45
Ford                45
Zetor               55
Challenger        55
Ford                55
Zetor               66
Challenger        66
Ford                 66
Zetor               96
Challenger        96
Ford                 96
Message 1 of 15
(3,847 Views)
This works.  (That green thing is a Sort Array__ogtk.vi)
Message Edited by jcarmody on 12-09-2009 11:52 AM
Jim
Message 2 of 15
(3,829 Views)
... and if you are not fond of green, an array of clusters will sort the array based on the first element in the cluster and the second will be used to break ties. So use the cluster order to determine on which filed it get sorted.
Ben
Message 3 of 15
(3,824 Views)
actually in my original post I had a brain-lapse on what the final sort needed to be....
I was looking for this:
Challenger        45
Challenger        55
Challenger        66
Challenger        96
Ford                 45
Ford                 55
Ford                 66
Ford                 96
Zetor                45
Zetor                55
Zetor                66
Zetor                96
thanks for the quick response.
Message 4 of 15
(3,804 Views)
Now I'm sure I've gone off the deep end...
Jim
Message 5 of 15
(3,798 Views)
Ben wrote:
... and if you are not fond of green,[...]
Ben
What is this world coming to? Smiley Wink
Jim
Message 6 of 15
(3,796 Views)
Jim, are you aware that the CCT easily allows you to have the FP and BD in the same PNG? No need to make two.
___________________
Try to take over the world!
Message 7 of 15
(3,793 Views)
Thanks.  I saw that possibility but was worried about the snippet extractability of a BD/FP CCT PNG (:))
I tested it and it worked.  I should have tested it before...
PS - I'm not stepping on anybody's toes with the CCT plug in my signature, am I?
Jim
Message 8 of 15
(3,777 Views)
jcarmody wrote:
Ben
Smiley Surprised
Did I just do a freudian to expose my real objection to global warming types i.e. I am against everything green?
Nope.
Ben
Message 9 of 15
(3,775 Views)
No. It's there for people to use, so any publicity is good, as long as it's not too much in-your-face.
___________________
Message 10 of 15
(3,765 Views)
