Logging Multiple Thermocouples
Hi Everyone,
I'm trying to monitor 4 Thermocouples simultaneously using a cDAQ-9174 and a NI 9211 thermocouple module. I'm very new to LabView. I found a VI that appears to do what I want elsewhere on the forum (I'll attach it), but I can't seem to make it work beyond recognizing the first channel of data.
I'm thinking I may be missing something simple when it comes to selecting the analog inputs fort the VI, in order to get all four channels working.
I'm also open for suggestions of a better example VI that can log 4 thermocouple readings simultaneously.
Thanks for your help!
(5,352 Views)
How are you specifying the thermocouple channels?  The VI you have will work as long as they are specified correctly.  It should be something like "cDAQ1Mod1/ai0:3".
(5,336 Views)
I think that may be the problem --I don't know how to specify channels. I can get the first graph to work with each of the four thermocouple input channels, but I can't get them to work simultaneously, as the input selector only appears to control the first graph/display.
(5,331 Views)
Accepted by Graham123
You've got to type the ":3" at the end of the channel.  Pick channel 0 from the list then add the ":3" to it.  That tells DAQmx that you want channels 0 through 3.  I have slightly different hardware (a 9213 instead of 9211) but your VI read the first 4 thermocouples I've got connected and plotted them in the first four stacked graphs.
(5,311 Views)
Thanks so much! That worked for me.
(5,270 Views)
