Logging Issues
Hello Everyone, The issue I'm facing is that data logged is not showing the name of the channel and its combining all data into one file. Kindly, give me some suggestions to amend changes. I have attached a picture showing how i combined all the graphs data into one write file. I want the file format to be changed and divided based on channels with their respective data. Thanks in advance
(4,495 Views)
No attachment.
Be sure to include your actual VI and not just a picture.
Also, exactly what does "the file format to be changed and divided based on channels with their respective data" mean?  Provide an example of how you want it to look.
(4,482 Views)
Thank goodness you forgot to attach the picture.  Do not attach a picture!  Instead, attach the actual VI so we can inspect it, edit it, see "behind" the Case Statements, even try out some of the code and figure out what it does.
We need to see the code in order to understand it and make suggestions.
(4,481 Views)
As suggested by others its always better to share the code which you have tried, so that iys easy to debugg and provide you solution.
to my knowledge and, if i try to get something from your explanation you can use TDMS File format and you can store the values in different sheets.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PcCAI&l=en-US
(4,454 Views)
I'm getting all the data in one file without description. Its getting the data from the sources. I want different properties such as voltage, current etc to be displayed in the file with their respective data. Kindly help. Thanks in advance
(4,356 Views)
Sorry, here is the file.
(4,355 Views)
