‎10-06-2005 07:09 AM
‎10-06-2005 07:47 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.‎10-06-2005 08:38 AM
Check out the following example at NI KnowledgeBase. I know it is for an image, but once you see it you should be able to modify it for your needs:
How to Display an Image from the Web in LabVIEW
Regards;
Enrique
‎10-06-2005 05:52 PM
Datasocket method has worked a treat....thanks very much! Exactly what i wanted to get.
Thanks Thanks
