Loading an INI file to cRio and reading/writing
I'm using an INI file to write/Read config data on a cRio. If I run my Vi on my development laptop, everything works fine once I specify the path. The issue I am having once I try to use the Vi on the cRio is that the file isn't deployed.
How do I get my INI file on to the cRio and set the path address up correctly?
Message 1 of 32
(6,511 Views)
Accepted by Lbee11
Hi LBee,
you need to include this file as "additional data" in your AppBuilder spec for the RTEXE. It will be stored in a "data" subfolder of the RTEXE filepath…
That's what I call in my cRIO main VI first to get the "data" folder path:
(The subVI just strips any filenames from "current VI path" and outputs a verified folder path.)
Message 2 of 32
(6,504 Views)
I just use Application Folder and it gives the path to the folder containing the executable (or project file).  Makes that subVI obsolete.
As far as the in file, you can also use WebDAV or FTP to copy the file to the cRIO.
Message 3 of 32
(6,483 Views)
I used the following in the end to achieve the result I needed, obviously the string is supposed to be wired!!
Message 4 of 32
(6,473 Views)
Hi LBee,
your file path handling really looks "strange"…
Why not use StripPath/BuildPath? (It would be much more safe because of differences in filepaths between Windows and Linux/whatever might be used on your cRIO!)
And as crossrulz said: use the AppDir constant!
Message 5 of 32
(6,469 Views)
Plus that code will not work in a built executable.
Here is the VI I keep in my library for such an occasion.  It creates a path relative to the folder containing the executable.  If in the development environment, the folder of the project file is used.
Message 6 of 32
(6,466 Views)
I've changed the path wiring to this:
This gives me the same result as before. If I try your setup, for some reason my Vi does not see it as a valid path when running on a cRio
Message 7 of 32
(6,457 Views)
У меня такая же проблема, как вы ее решили?
Message 8 of 32
(6,001 Views)
Hi Andry,
you should write English in this LabVIEW board.
I have the same problem as you solved it?
Could you attach your current VI you have problems with?
Did you store the ini file in the cRIO?
Did you check the file to be in correct folder?
Message 9 of 32
(5,991 Views)
Или вам нужно полностью?
С уважением)
Message 10 of 32
(5,978 Views)
