Loading a different RT Menu using VI server
        Using LV 7.1 can I select what Run-Time menu I would like to run a VI with. For example I would like to have two RTM files. Depending on the situation I would like to lauch the VI with either one or the other Menu. If this is not directly possible before running the VI, is it perhaps possible to send a flag and then do once the VI is running.
(2,686 Views)
For the rest of the community, refer to this thread for the answer.
Wendy L
LabWindows/CVI Developer Newsletter
(2,668 Views)
