Load all website
Hello !
Tell me, please, how can I get the height of the columns?
If you open the chrome (PKM> look at the code (ctrl + shift + I)), then the height of the columns can be seen. (see 333.jpg)
But in labview I can not get this data.
Tried:
HTTP Client -> Get
DataSocket Read
But with the help of these two methods I get what in the chrome (PCM> view the page code (ctrl + U))
Thanks for any help!
Message 1 of 11
(6,857 Views)
Hi Sergiv,
it seems you look at an entry in the CSS document to that HTML website.
When you want to read those information you need to load and parse the CSS too…
Message 2 of 11
(6,831 Views)
Thanks for your reply.
What tool can I use to load CSS?
Message 3 of 11
(6,828 Views)
Hi Sergiv,
here's the HTML source code (image) of your last message:
Do you notice this "<link href=…" in line 21?
You can use HTTPGet to read that stylesheet too…
Message 4 of 11
(6,822 Views)
Yes, I noticed. I tried on my example. I looked through all the css, but in no one found information about the columns. Could you tell me how to find them?
site: https://yobit.net/ru/trade/LIZA/RUR
Message 5 of 11
(6,813 Views)
Hi Sergiv,,
your website will load a ton of other resources:
I'm no expert in modern website design nor in JavaScript, so I guess you will have to look for a lot of files before finding the place of your rectangle definition…
(I guess it has to do with some of the JScript libraries because of the "highchart" description.)
Message 6 of 11
(6,807 Views)
In general, the experiments led to the fact that if you save the page on the computer and open it via GET, for example, then the data of the columns is there)
Now just do not know how to save the entire page. Like it does the chrome, for example, through "save as ..."
Tell me how to save the document completely?
Message 7 of 11
(6,784 Views)
Hi Sergiv,
the InternetExplorer allows remote control via ActiveX so you may try to load and save the website through ActiveX nodes…
(This will only work with IExplorer as other brwosers Edge or Firefox doesn't support ActiveX remote control.)
Message 8 of 11
(6,780 Views)
Does activex have a property for saving the page? Or how conservation is implemented?
Message 9 of 11
(6,773 Views)
Hi Sergiv,
The question is "Does the IExplorer ActiveX interface expose such a method?"
I don't know as I don't use this interface (and never needed so far)…
Why do you need to read those style properties anyway?
What is all this good for?
Message 10 of 11
(6,769 Views)
