Listbox behaves in unexpected manner
The Quick Drop Listbox does not show this bug, so we know someone at NI is aware of the issue and worked around it. I can count at least two dozen bugs fixed in LV11 that I would trade to have gotten this one fixed. And I mean all for one.
Message 11 of 18
(1,794 Views)
I can only confirm that the issue remains in LV 2013. That is just so sad.
Certified LabVIEW Architect
Message 12 of 18
(1,724 Views)
What about in LabVIEW 2014?
Message 13 of 18
(1,709 Views)
Don't know about LV2014.
But I found that there is a scripting property FocusRow that does the trick. Not very useful for most cases, but why is it not available without scripting? And why the 'FocusRow' is not the set when setting Value is a bit weird.
Message 14 of 18
(1,699 Views)
It is still there in 2014.
Message 15 of 18
(1,684 Views)
Update: I went ahead and re-reported this to R&D (# 488710). I'm not sure why no action has been taken so far, but hopefully they'll be able to take a look. Thanks for bringing this back to our attention!
Message 16 of 18
(1,654 Views)
There is a solution in this thread if you read through it all:
http://lavag.org/topic/16987-mclb-automated-selection/
Involves some private properties but there are some VIs posted that expose them for you to use.  Solved the issue for me.
-John
Message 17 of 18
(1,628 Views)
This CAR is reported as being fixed in LV 2014 SP1 and 2015, but it has not been fixed.  It affects multicolumn and single column listboxes.
Message 18 of 18
(1,576 Views)
