Linking events on front panel objects
I have inherited a project which has a small but stubborn bug in the event handling.
My front panel has two identical clusters labelled 'heatsink' and 'shroud'.
Each cluster contains a numeric control, called 'setpoint', and a Boolean button named 'set'  .
If I type in a setpoint, and hit return, it is supposed to set a click event on the Boolean button.  The problem which I have is that the Heatsink numeric sets an event on the shroud Boolean, rather than its own.
This is NOT occurring in the LabVIEW code.  I set a break point right at the start of the programme and I could still see this behaviour with the programme paused.
Both clusters are taken from the same typedef.
Any ideas?
Thanks in advanced, Ian
(3,174 Views)
Accepted by topic author Barionics
look properties of Button. Look like there are toggle by Return
(3,152 Views)
It would be so much easier to pinpoint the problem in your code if we had the code available to us, don't you think?  In addition to the code involving the Clusters, we would need the TypeDef.  If (as it should be) the code is part of a LabVIEW Project, the simplest thing would be to compress the folder containing the Project and attach the resulting ZIP file.
(3,133 Views)
Hello have you tried relabeled one cluster? If you need both control display the same name you can always use the Caption, but internally both controls will be named different.
Greetings!!!
Roger Garcia, Certified LabVIEW Developer
HTML tutorial
There are two ways to tell somebody thanks: Kudos and Marked Solutions
(3,126 Views)
Use Focus Key Binding property to control which of the two buttons will get the next "Enter"?
A Mouse down event on one of the two cluster can be used to control the switching.
Ben
(3,122 Views)
Sorry I haven't added any sample code, but I work in a secure environment, so it is not easy. I will see if I can add a code snippet which will do the job.
(3,104 Views)
