Link information from tables and show the "best " box.
Hello! I'm totally new to this great software and the truth is I'm lost 😧
I try to explain in more detail what I have to do, I hope you can help me please it's urgent T_T
I must make 3 tables should be linked to each other , ie a table where the name of a user will be manually enter, another where you manually enter the last name of a user and the third which will automatically enter the power of each user (for the automatic entry i will use a random data ) . Each table will have a box number , for example :
Table 1, Box 1: Paul
Table 2, Box 1: Gate
Table 3, Box 1: 3.74
Table 1, Box 2: Miguel
Table 2, Box 2: Ramos
Table 3, Box 2: 4.99
Table 1, Box 3: Maelle
Table 2, Box 3: Branco
Table 3, Box 3 : 4.98
I mean, I link the box to a table with the other three . And given that the program must compare the data in Table 3 (power ) and display data from the best user ( who has the highest power). In this example, the program should display :
BEST USER :
POWER: 4.99
(Is not nessesary save the information when i will close the program)
I do not know if I 'm asking a lot , I have a very clear idea in my head of what I have to do , but being a new software for my not know how to implement it .
Thank you in advance for your help and quick and ilustrative response! xD
Message 1 of 12
(3,176 Views)
It would be nice to post what you have done already and where you are in code.
-check this it be helpful to you
http://forums.ni.com/t5/LabVIEW/How-to-find-closest-value-in-array/td-p/1128281
uday
Message 2 of 12
(3,170 Views)
I dont know even how to start 😧 i can just make the tables and make the "random data" in table 3...
Message 3 of 12
(3,164 Views)
Accepted by Miguel_Exe
Did tried something with basic understanding of your question check if this is what you need??
-Still not clear what you mean by table??( In my opinion table is 2d array of values here if not please let me know.)
-That's the reason i asked you to show your code what you have done then it will be more clear.
uday
Message 4 of 12
(3,154 Views)
Thank you for you reply!
saw that you registered the program and is only 1 part of what I wanted, I attached a picture to this message with a draw to give to clearly understand my idea.
Thank you very much for your support!
Message 5 of 12
(3,120 Views)
Hi Miguel,
you should organize your data into a more appropriate structure, but for a starting you may try this:
Message 6 of 12
(3,106 Views)
Hi Miguel_Exe
-Please check the snippet it does exactly what you said.
-The Box 1,2,3 you mentioned are array indices.For example if you use table_1 and index it with 0(Yes, arrays index starts from 0), you will get first element which is Miguel-Vi used is Index Array.
-For linking you can use string concatenation. Get each element from array using proper index and use Concatenate Strings.
-I am getting the last Numerical Table and passing it to Array Max and Min to get where maximum value is and using same index (Box value) am getting full name.
uday
Message 7 of 12
(3,095 Views)
Hi udka,
to check for MAX values on a string array is "kind of dangerous" - I would not trust this to work with all strings. That's why I tested the DBL array in my snippet...
Message 8 of 12
(3,069 Views)
Hi GerdW,
-Infact i did the same first, converting the string to float and then got MAX values.
-But then later i thought converting is redundant. Can you please provide more info on why its dangerous and where it fails??
uday
Message 9 of 12
(3,061 Views)
Hi udka,
strings are sorted lexically, while numbers are sorted by their value.
Which string is bigger: "222" or "39"? Which number is bigger: 39 or 222?
Also using strings will go insane when the user hits the wrong keys: what happens when the user inputs "123-23" instead of "123.23"?
Message 10 of 12
(3,048 Views)
