Link One specific vertical Cursor with the desired Y axis on a muti Y axix Graph
In my application I have a Graph with 4 Y-axis to analyse acquired data with 2 cursors (2 vertical and 2 horizontal).
I would like to display in 4 different "numeric Indicator" the value of the horizontal cursor for each Y Axis.
My problem is that I can not associate de cursor with the desired Y axis.
I am sendig my aplication attached to help you understand my problem. I am sending, also, one "print screen" with the locattion to show where this CODE is. I think you will not have problems because it is a very simple VI (despite some of the comments are in portuguese).
I hope you could help me.
Thanks for your attention,
Rafael (BRAZIL)
PS: About 6 months ago I asked
for help by the support with the same problem. At that time, the problem was solved, but the same apllication on another VI I can not understand what is really happening.
HOW TO RUN the VI:
1 - Open VI ("Plot Analisys5 - State")
2 - On "Plot Analisys5 - State", on the path "Arquivo de SETUP", select the correct adress for this file (it is attached to the ZIP file).
3 - Press "Open Edited File" and select the file "teeeessssssste.xls".
4 - If you move both cursors, you will see that they are both related to Y axis "Temperature", as displayed bt the indicators under the graph.
(2,487 Views)
Hi Rafael,
I think your question has been answered on this thread. Thanks!
Jeremy L.
Jeremy L.
(2,487 Views)
