Linear interpolation problem of array
hello evryone!a little problem catch me ,iwant to replace the value of array  by  Linear interpolation.  i wii attach my vi ,when you haven seen it ,you wii understand what i mean.thank you ,good luck for you !
(3,207 Views)
No, I don't understand what you mean, even after looking at your code.
There is an array labeled "want". Which of the outputs do you want to look like that and how does it relate to the current default input?
(3,187 Views)
thanks for your reply, the" original" array is the default array ,"want" array is what i want ,but you will find the difference between "original "array and "want "array,you will find the The same values in "original" array haven been moven ,it's not real "disappear" ,i want use linear interpolation replace the "disppear "value ,when you run the vi,you will find the the same value have been replaced by linear interpolation (6 become 6.5;10 become 10.3333,106667),but my vi only work Increasing,when the value from"original "array decreasing ,the answer is not right,so can you deal with it? thanks !
(3,161 Views)
i have did it,thanks for your reply!Smiley Happy
(3,142 Views)
