Linear fit not working as expected?
I'm using the NI_AALPro.lvlib:Linear Fit.vi on an array of vertically stacked points. However, the result makes absolutely no sense, the fitted line doesn't represent the input data.
But if I rotate the points by 1 degree, the fit seems to work...
Why is that and is there a function or a way to properly fit the points regarding their orientation?
Thanks in advance!
I have attached:
  • The VI itself
  • A screenshot of the VI
  • The test image (no rotation)
  • The test image (rotated 1 degree)
  • A screenshot of the fitting result (no rotation)
  • A screenshot of the fitting result (rotated 1 degree)
Message 1 of 22
(4,913 Views)
Message 2 of 22
(4,910 Views)
Hi optimus,
can you attach your VI with a typical set of "blob coordinates" made default in the indicator?
What's the point of the FOR loop? Why not use simple math:
Message 3 of 22
(4,884 Views)
Thanks for your quick reply! I adjusted the VI, it seems I thought a bit too complicated.
I included the blob coordinates (in the 1600x1200 px image) as a constant.
Message 4 of 22
(4,869 Views)
Unfortunately you did not attach the VI according to your image.
Please attach your VI with that "blob coordinates" constant!
Message 5 of 22
(4,860 Views)
Sorry, my mistake. I'll upload it shortly
I adjusted the file paths, you might need to update them with the location of the test picture I uploaded if you want to use that.
Thanks again!
Message 6 of 22
(4,751 Views)
Sorry, my mistake, here it is:
Message 7 of 22
(4,817 Views)
Hi Optimus,
using a XY graph the interpolation looks quite ok. See attachment…
Message 8 of 22
(4,806 Views)
Hm, yes it does. But why is it so weird in case of my blobs?
Message 9 of 22
(4,799 Views)
Hi optimus,
I thought that "blob coordinates" constant were real blob coordinates?
Why should it display different on your IMAQ indicator than on my XY graph?
Message 10 of 22
(4,794 Views)
