Linear Voltage Ramp (Analog)
Your program worked for me when I tried it with a valid device name.  I would check the device name in Measurement and Automation Explorer to make sure that it is correct in your program (Simon showed how to do this earlier).  Also, I attached a screenshot of how to disable auto scaling the x-axis so you will have a constant time axis.
Message Edited by Jordan F on 12-23-2008 12:42 PM
Jordan F
Message 21 of 26
(1,688 Views)
Thanks all Chris Simon and Jordan.
Theese informations helped me very much.
You all are very kind thanks again.
Wish success at work.
I will pray for you all the time 🙂
Message 22 of 26
(1,680 Views)
Hi Everybody its me again 🙂
I have just get my DAQ card it is NI USB-6009 8 Inputs, 14-bit,Multifunction I/O
I have connected and tried the vi the last error (200220) is not occured its ok but there is another error.I have posted it and
I have posted my MAX window.
Can you help me with this
Thanx.
Message 23 of 26
(1,668 Views)
If you look at the specs, you will see that the analog output has a maximum range of 0-5V. You are requesting  -5 to +5.
Message 24 of 26
(1,663 Views)
Hmm i can see now.My DAQ isn't suitable for -5 +5 range then.
Cant i work my vi with this DAQ?
It does not support negative values?
Message 25 of 26
(1,659 Views)
Mr Dennis.
Thanks for reply
Now i tried in 0 +5V range but error occures again anyway.
Is it happens because of the +5v -5v values in vi block diagram ?
Thanks again.
By the way İ changed the block diagram and it works true with 0 +5.
Message Edited by Siyah on 12-24-2008 06:45 AM
Message Edited by Siyah on 12-24-2008 06:48 AM
Message 26 of 26
(1,655 Views)
