Linear Temperature Ramp Program
@realperson1223 wrote:
I have been trying to figure out how to increment through an array without using the inner for loop. How would one go about doing this?
What is "increment through an array"? You can use index array using an incrementing index held in a shift register, for example. Make sure that the index remains in the valid range.
Message 11 of 11
(624 Views)
