Line resizes when using zoom factor
I have a problem where if I use the draw line function on a 2d picture and then use zoom factor, the length of the line will remain the same, but thickness will scale with the picture.  Is there a way to prevent this from happening?
(2,639 Views)
Here are two pictures to show you guys what I mean.  The first is a 2d picture without zoom and the seconds is the same picture with a zoom factor of 5.
(2,586 Views)
Accepted by topic author kevlightning
That does not make sense. If you zoom , the length will scale proportionally with the picture, but the thickness won't. So it's more or less exactly the opposite from what you're saying? Anyway, I think the problem is clear.
The only way around it is to scale manually. E.g. not using the picture control's zoom, but redraw everything with your own coordinates and line widths. Sad, but true...
(2,566 Views)
