Limit Display with Set Point and Data
I am stuck.  I an using one of LVs Limit functions that does a great job of doing limit testing.  Now, I need to add the Set Point to the data and limit lines.  Can this be done.
NOTE - This is written in LV 8.0 and requires Developer Suite
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,922 Views)
Hi Matt,
I'm a little unclear about what your question is.  Could you please clarify a little bit.  What exactly is the set point? Thanks.
Christopher W
(2,895 Views)
The question was correctly answered by technical support.  I know when no on answers it on the discussion board that it is not a common issue.
Thanks.
matt
Reference#7118155
Matthew Fitzsimons
(2,887 Views)
