ERROR MESSAGE INDICATIN X-FLOW PROGRAM MAP RETURNED ERROR CODE
sir,
I am working on a project using ni rio-7831R uaing labview fpga1.1, on compiling on to the device i am encountering a error giving follow message:
Problem encountered during the packing phase.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
so please, recommend me the action so that i could compile my project without error.
vamsi
(3,962 Views)
Hi vamsi,
It sounds like the FPGA may be overmapped (basically, there is not enough space on the FPGA to fit the compiled code).  Are you able to compile a very simple program (for example, one that adds two numbers and displays the result?
David H.
Systems Engineer
(3,939 Views)
Was this problem resolved?
Joseph D.
National Insruments
(3,886 Views)
