Limit Check Result.VI not working
I have Sub-VI for showing the limit check result that displays the result after a limit check is performed as 0-PASS, 1-FAIL and 2-MARGIN. I cannot get it to display(report) the correct value.
Thank you
(3,173 Views)
You provide insufficient information. Where does C/Matlab fit into all this? Have you contacted the driver mfg.?
(3,164 Views)
Matlab doesn't fit in anywhere. I'm using labview2013
As you can see the posted screenshots.
I connect to a R&S FSV40-->recall saved state(with limit lines configured)-->attempting to read limit check result.
(3,155 Views)
Contact rohde-shwarz, they wrote the VI.
(3,149 Views)
the most important thing in remote-control: never use continuous measurement mode. Check out our 10 tips/tricks for LV drivers:
https://www.rohde-schwarz.com/applications/10-tips-tricks-on-how-to-use-rohde-schwarz-labview-instru...
You do save/recall, you are in contiunous mode, your program runs faster than your instrument's sweep and therefore you get incorrect limit check result.
After File Recall:
- call Configure Acquisition.vi with Sweep Mode Continuous=false
- call Initiate.vi - this performs the sweep and waits for it to finish
- call LimitCheck
Tip: in the Express VI configurator you can use the Hi-Level Function tab to see and use hi-level function where the desired attribute is used (see the picture in the attachment)
Happy remote-controlling 🙂
(3,062 Views)
Hi MM_RohdeSchwarz
Thank you for responding to my question.
I have implemented the .VI you listed:
I still get the same result. please see my attached video.
(3,042 Views)
Hi jbent,
sorry, I forgot to mention one other thing - you have to tell the analyzer which limit is your Limit1 - that can not be done with the setup file, you have to set it afterwards. Find my working example in the attachment. Let me know if it worked.
BR
Milo
(3,025 Views)
