11-07-2012 11:32 PM
11-07-2012 11:43 PM
11-08-2012 01:09 AM
So far I just see Smoke and Mirrors![]()
Please attach your file.
steve
11-08-2012 01:13 AM
11-08-2012 01:25 AM
Still no program....
11-08-2012 08:55 PM
11-08-2012 09:01 PM
Here is the program
11-08-2012 09:45 PM - edited 11-08-2012 09:49 PM
While this appears to be a different VI, it seems heavily related to the code you posted in your other thread.
Except your problems here seem to be worse because you've added more sequence frames and case structures and while loops in ways that are just never going to work together. Many of your case structures in the later sequence frames are completely unnecessary. The code is in the True case. But the False case can never run anyway because the boolean wire coming in must always be true since it is dependent on the early while loop stopping by way of a True boolean to the stop terminal.
In this code, you have a lot of hidden stop buttons. Along with the way too deep nesting of while loops, you have a situation where you can never stop your code, either because the user can't see some of the stop buttons needed to stop some of the loops, or you need to be sure of executing just the right combination of Stop buttons so you can get the nested while loops to stop without restarting again.
Please refer to my comments in the other thread and then take the LabVIEW tutorials. You may even want to turn on Highlight Execution to watch how the data flows within your VI. This should make it more obvious as to why your code just doesn't work.
