11-01-2012 11:25 PM
11-01-2012 11:27 PM
How are you detecting the alarm? What hardware are you using with this application?
11-01-2012 11:36 PM
11-01-2012 11:38 PM
How is this signal getting to LabVIEW? What hardware are you using?
11-02-2012 12:08 AM
11-02-2012 09:10 AM
Ok. Depending on what you need to run the other device, the NI Elvis board has (I beleive) an analog output port as well as some Digital outputs. Depending on what voltage is needed to run the other device you might need to create an Op Amp circuit to increase the voltage as needed. Since its an NI elvis board, creating that circuit shouldnt be a problem 🙂
11-02-2012 09:15 AM
11-02-2012 09:18 AM
Thanks RavensFan
11-06-2012 12:25 AM
11-06-2012 08:31 AM
Anything is possible, you need the hardware to do it. You can use an opamp circuit, or you can buy an NI relay card.
