License for LabVIEW NXG Community Edition
Hi all,
I've just downloaded and installed LabVIEW NXG Community Edition 5.1. After the installation I'm supposed to activate the software using the identity-based activation, however the NI License Manager says that "there is no license associated to my user account".
How can acquire a license for a product which is free for non-commercial use?
Any help will be appreciated.
(3,344 Views)
You need to be logged into the same account that you downloaded LV NXG CE when you install it.  That being said, I had LV NXG CE 5.0 installed successfully, but I got the same error as you when I tried NXG CE 5.1
I couldn't get around it, but I figured since LV NXG 5.1 was basically DOA, I didn't follow up on it.
Bill
CLD
(Mid-Level minion.)
(3,314 Views)
Thank you Bill,
I've installed LV NXG CE 5.0 and when I go to register it I keep getting the same error. If I try again I get the message "Activation failed due to server error". It seems that I can extend the evaluation period so I'll do that, but it's not what I was expecting.
Cheers,
Richard
(3,269 Views)
Have a look at the following article (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000ww6wCAA&l=en-GB). If it doesn't help solve your problem, as outlined in the article you can create an activation service request even if you do not have support entitlements.
Thank you,
(3,256 Views)
