Level change indicators
Hi.
My VI is measuring Ing the level of water in a tank, and want I LED indicators to tell me if the level is  Increasing, decreasing or stable.
There's 1 indicator for each case.
How do I compare the current waterlevel to the level 1 sec ago?
So far I've made at sequence structure (in a while loop) that's is comparing the value in seq.2 to the one of seq. 1.
It only works once.
Any ideas to a solution?
Kat
1. year engineering student
Message 1 of 10
(5,365 Views)
I can't see your code (I have LV 2014), but for that kind of timing you may consider putting the time and water level into a shift register. Put your code which compares the water levels into a case structure, and only update if 1 second has elapsed from the shift register value. If it has, make sure to update the shift register with the current time. You can use things like tick count (ms), high resolution (sec), and time stamp to keep track of time.
Message 2 of 10
(5,358 Views)
You should get rid of the sequence structure and the local variables. Both are unnecessary and make it much more difficult to do what you want.
While you can meet your stated goals without, it might be a good time to learn about state machines.  Your states could be "Increasing," Decreasing," and "Stable." You might also have states for empty and overflow.
To get a decreasing value, Input will need to include negative values.
Consider what should happen if Tank2 has a negative value or a value greater than 100.
Lynn
Message 3 of 10
(5,349 Views)
Accepted by topic author KatrineRav
Use that Feedback Node to store the previous level.  From there, just subtract the new and the old and use the Sign function.  This will give you a -1 (decreasing), a 0 (stable), or a 1 (increasing).  Just use a case structure to interpret this into your boolean indicators.
Message 4 of 10
(5,343 Views)
Nevermind my post. The one above is a cleaner solution
Joe.
"NOTHING IS EVER EASY"
Message 5 of 10
(5,331 Views)
Thanks a lot!
Message 6 of 10
(5,304 Views)
Is the 1 to infinity needed on the case structure? It seems like that function only has 3 output possibilities.
Message 7 of 10
(5,293 Views)
Yes it is.  The case structure just sees a numeric.  You therefore must cover ALL numerics.  So the 3 cases here are "..-1", "0", and "1..".
Message 8 of 10
(5,279 Views)
Thank you, I see now. That is nicer than having a default case.
Message 9 of 10
(5,271 Views)
I would recommend to just us an array of three boolean indicators (And use the array caption for labels). It is much cleaner code if you don't need to use a case structure and you only need exactly one indicator.
I changed the input to I32. If the Value is really a DBL coming from a real instrument with noise, you most likely never get an equal. You probably should introduce some deadband such that very small changes are ignored (Not shown).
Also note that you have a hidden race condition, because the tank indicator lags behind by one iteration and does not show the current level. You need to wire it to the output of the addition, not the output of the shift feedback node. You are also comparing the input with the tank, which is logically incorrect.
Message 10 of 10
(5,243 Views)
