Learning to program an fpga and using its ADC function
Hello All
I'm trying to write a labview program that takes reading from an analog discovery 2 fpga and convert it to digital and then binary to be streamed to PC through serial.
This is what I have now, I have a problem with the waveform read function from the Digilent WF add on package where I  try to connect between the read function and analog to digital VI it tells me the source is 1D array waveform DBL and the sink is just waveform DBL, I'm not sure what the difference is. Also how can i design the serial output to stream to pc??
Cheers
Richard
(1,320 Views)
How many "waveform DBL" are there in "waveform DBL"?  How many in "1D array (of) waveform DBL"?  Now do you see the difference?
My preferred way to "stream data to PC" is to use Network Streams.
P.S. -- I haven't looked at (and won't look at) your "pictures".  If you want us to see your code, attach your code (as VIs, so we can examine, and even test, it).  You might need to attach multiple VIs, but you can compress the folder containing them and attach the resulting .ZIP file.
(1,283 Views)
