Learning GPIB Basics
Hi! I am starting to learn LabVIEW to use GPIB to control a few motors for my research. I have no prior knowledge of LabVIEW or GPIB so I wanted to ask for suggestion of resources from where I can learn the basics of LabVIEW and GPIB. Thank you in advance 🙂
(1,943 Views)
There are links at the top of the LabVIEW forum that you should follow.
When dealing with GPIB, I would recommend just getting used to VISA.  VISA abstracts most of the details and it lets you easily change to using Ethernet or serial instead.
GPIB is a dying bus, mostly due to cost.  I use Ethernet to communicate with my instruments whenever possible, followed by RS-232 (serial).
(1,923 Views)
This is a great tutorial to get started - VIWeek 2020/Proper way to communicate over serial - LabVIEW Wiki
Santhosh
Soliton Technologies
(1,900 Views)
