LeCroy Scope
I'm using LeCroy WaveRunner 6100A scope and I have a problem with
sequency memory, so maybe you could help me.
It's easy to set the sequence mode on and acquire the waveforms into
the memory. Then I use math function called segment to be able to see
and process segments separately.
I would like to use LabView to do calculations to these waveforms. So
to do that I really need to import those datas from scope program to
LabView. And I don't know how to access those segments in scopes
memory. There might be just a simple command to do it but I just don't
know what it is.
I would really appreciate your help. And if you need more information
to be able to help, don't hesitate to ask.
(2,967 Views)
Please see the post here.
Thanks!
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(2,952 Views)
