Last array element
Hi
In run mod, when I add elements in array, I want to see the last element of array automatically.
How can I do this.(without using vertical scrollbar.)
(9,100 Views)
Set the Index Values property to a value such that you see the index you want.  If you have more than one visible element you'll probably need to use Number of Columns and Number of Rows and some math to figure out which index you want in the top left.
Tim Elsey
Certified LabVIEW Architect
(9,096 Views)
Check Delete from array, if index is unwired it's automatically the last element selected, and the output Deleted portion is thus the last element.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(9,089 Views)
Accepted by ömer
In a thousand words or less.  You use property nodes to programatically access objects properties.
(Yes you have to run it twice to see the result I didn't set a default value)
"Should be" isn't "Is" -Jay
(9,088 Views)
Tanks for your answer.
Your example was very illustrative for me.
My problem was solved.
Thanks.........
(9,034 Views)
