Large Cluster does not appear on front panel.
The input and output of my call library function is a large cluster containing 830 elements.  The cluster icons are seen on the block diagram, but there is no trace of the clusters on the front panel.  When I double click on the cluster icons, I am taken to the front panel, but there is no trace of the clusters.  Also,  the scoll bars on the front panel do not work.  Any help with this matter would be much appreciated.  Thank you.
(5,038 Views)
When you double click on the cluster's terminal and the front panel comes to the front, is anything selected?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,035 Views)
Could you attach a simplified version of your VI (at least containing your cluster in question)?
(5,034 Views)
Hmmm.....
Maybe hidden?
On BD right-click and see if "Show control" is an option.
Ben
(5,029 Views)
Ben wrote:
Maybe hidden?
 If it is hidden, it would show as a "ghost" when double-clicking the terminal. It also does not explain why the scrollbars don't work.
I suspect some corruption.... 😉
(5,024 Views)
