Large Arrays and Memory
Accepted by Valerie77
Valerie,
Here is a quick image of how to start to use the method I described above.  This would be expanded to the six shift registers you have.
Lynn
21285i97CB5CB13590CDDB
Message 11 of 14
(1,492 Views)
Ok I will work with it.  Thanks for the help 🙂
Message 12 of 14
(1,484 Views)
To the veterans out there...is this form more or less desirable from a memory standpoint than code with multiple cluster arrays shown above?  Seems like X data are saved fewer times in this implementation, but perhaps there is an overhead associated with the build cluster of arrays and build array of clusters operations in each loop that offset these savings.  (Oops, forget to increment the index).
21297iAFD90A156013BDC7
Message 13 of 14
(1,474 Views)
@Houligan I can bet money on that the build cluster inside the loop makes a new array, thus a data copy. It must be better to work directly with the clustered arrays.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 14
(1,471 Views)
