Laptop Serial VISA problems
Hi, I'm having problems getting a laptop to run the code that I have written and tested on a desktop.
Basically I need to run a stepper motor via the Serial port.
My code works perfectly with the PC, however the laptop delivers back the an error message (see attached)
The stepper motor comes with a piece of test software and this does work on the laptop, so I can see no logical reason why Labview wouldn't let it.
Is there a logical reason for this?
Any help would be greatly welcomed as I need to show my work on Friday and I don't want  to take my PC 300 miles up to London on my lap
Regards Wes
(3,380 Views)
It would seem that you don't have VISA installed. The error code means"VISA:  (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded." but you get the "undefined" message when VISA isn't installed at all.
(3,375 Views)
I have re-installed Labview and put on the most recent DAQMX software.. but no luck with that
How can I install the VISA?
Wes
(3,373 Views)
Look here.
(3,363 Views)
U Beauty Smiley Happy
Cheers mate
(3,350 Views)
