Language Problem when building executable
I'm having a weird issue when building executables.  Labview seems to forget the english language.  I have tried selecting English exclusively as the run time language but when i do that i get a "No supported languages installed!" error. Everthing works fine in the development environment.  It only seems to apply to application menus and not custom user menus.  Thanks for any insight.
(4,434 Views)
Accepted by Jed394
Hello Jed394,
I took a look into the issue, just to be sure the error thrown was “No support Language Installed,” correct?  Check to see if the language of your operating system and the language LabVIEW is using is English.  If these are both English, then it looks like this is an error due to installation issues in the run-time engine.  Try to perform a repair by going through the install menu of LabVIEW.  The following link will help you with the repair: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument
If you have any further issues, please let me know. Thanks!
Matt S.
Industrial Communications Product Support Engineer
(4,410 Views)
Thank you for the info.  Reinstalling the 2011 spl1 runtime seems to have fixed my issue for now.
Matt, if you happen to see this one more question.  Are run-time installations backwards compatible or do you have to install the specific runtime for each development?  I.E does 2012 runtime support 2011 sp1.  Thanks.
(4,403 Views)
Hi Jed394,
Good to see that the repair worked.  As for your question on run-time installation, they are not backwards compatible.  There’s some literature on this here: https://www.ni.com/en/support/documentation/compatibility/17/labview-and-labview-run-time-engine-com...
Matt S.
(4,400 Views)
