Lack of data triggering
If my system does not receive any data within a ~10 second span, it begins spitting out values of 0 into the histograms.  I have already removed the error messages so that the system does not stop entirely.  I want to system to wait indefinitely for a data point ... is there a variable that sets this time limit for triggers?  I'm using ni-scope VIs for the DAQ process.
(3,305 Views)
Is it possible to post your code so we can look at it?  Its hard to tell what is wrong when you give so little to go on.
- tbob
Inventor of the WORM Global
(3,302 Views)
Ya, I'll post it tomorrow when I'm back in the lab.
(3,299 Views)
(3,266 Views)
Hello bbentelin,
Could you tell us what daq device you are using? As well as more information about your application? You mentioned in your first post you are using NI-Scope for DAQ device, do you have a Multifunction DAQ device or NI Scope device?
Jignesh
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(3,243 Views)
Accepted by topic author bbentelin
Look at the context help for the function niScope Multi Read Cluster.vi, then look at the description for the Timeout terminal.  It says to use a value of -1 to wait for an infinite amount of time for data input.  If you create a constant on the terminal, you will see that the default is 5 seconds.  That is why you are getting values of 0 even though there is no input.  But setting the timeout to -1, your problem should be solved.
Bon Chance!
- tbob
(3,226 Views)
Merveilleux! Merci Beaucoup!
(3,216 Views)
