Labview
Hi Bhavani,
@Bhavani08 wrote:
I am actualy struck at the term u(t-t1) and u(t-t2),it is unit step function and how should it be actually given?? I tried using formula node and formula waveform but there was no function that implements the step function in both the cases. I am unable to give the u(t-t1) and u(t-t2) as input,even if I try I got error.
Where does those terms appear in the formulas given in your previous message? Where did you mention those "unit step functions" before? I thought the "u(t2)/u(t1)" terms refer to voltage values at a given time…
So "u(t-t1)" is 0 for t<t1 and 1 for t>=t1? What about a simple comparison followed by a select node (or just a BooleanTo0/1)?
Why do you need a formula node when you can use simple math functions?
What is a "formula waveform"?
Just to give you an idea:
Message 11 of 26
(2,839 Views)
This one? https://en.wikipedia.org/wiki/Heaviside_step_function
Looks like this would do the trick:
Message 12 of 26
(2,834 Views)
It can be even simpler. Rather than calculating the difference t-t1 and then using your code, you could directly use a ">=" node with the two arguments t and t1 wired to it, in place of the >0 function. Just as Gerd is using in his sample.
But other than in Gerds example, A is likely the time domain signal to analyze (so most likely really should be written as A(t) ) and t is the loop iteration counter scaled with the sample interval time.
Rolf Kalbermatter  My Blog
Message 13 of 26
(2,821 Views)
@rolfk wrote:
But other than in Gerds example, A is likely the time domain signal to analyze and t is the loop iteration counter scaled with the sample interval time.
According to Bhavanis table A is given as constant value of "A=1".
I used the Ramp pattern to create that "time array" from 0 to "T end", no scaling needed.
Update to the image above: due thanks to polymorphism you don't need the FOR loop…
Message 14 of 26
(2,812 Views)
Seems logical but makes little sense. That calculates some variation over a monotonically increasing ramp with the only variable inputs being t1 and t2? Sounds not very useful to me in terms of AC measurements.
Message 15 of 26
(2,803 Views)
Hi Rolf,
I try to translate the formula given by Bhavani in its given pure logical/mathematical form.
When Bhavani provides other formulas then (s)he has to change the implementation as well…
Message 16 of 26
(2,800 Views)
@GerdW wrote:
Hi Rolf,
I understand. Just pointing out that it's likely not quite the solution yet. Without more input from the OP, it's however all we can do.
Message 17 of 26
(2,785 Views)
Actually I tried the block diagram given above, I am not able to get the desired output. Is there any other way to generate voltage sag??
Message 18 of 26
(2,773 Views)
Hi Bhavani,
What is the expected/desired output?
Why don't you attach your VI/implementation?
When you attach a VI: include data, which shows the desired output in contrast to the output you get currently…
(You could implement the desired algorithm in an Excel workbook to create the "desired output". This way we could compare your Excel algorithm with your LabVIEW implementation.)
Message 19 of 26
(2,769 Views)
The desired output required is being attached,
Message 20 of 26
(2,760 Views)
